Выходит ошибка 210 что это? Doosan DX225LCA [Ответы 2]
Doosan DX225LCA
Вопрос 427787
alfir190685, Екатеринбург
Выходит ошибка 210. Что это?
VladVic, Калининград
Эксперт, Ответы: 680, Оценили: 1155 раз
Ошибка связанная с редукционным клапаном насоса, подробнее смотрите здесь:
Doosan DX225LCA Excavator Fault Codes List – FMI & V-Codes See also: Doosan Service Repair Manuals PDF
Failure Information Code at Machine Side
Code Failure Component Measuring Points Correct Value Remarks
Active Passive
V201 Gauge Panel
Communication Error
CN7-4
CN7-5
R = 60 ±5 Ω It is a composite resistance of CAN line. This value has to be measured by connected condition of CAN line.
V202
Ecu Communication Error
CN4-4 CN4-5
R = 60 ±5 Ω
V210
Pump P/V
CN1-10 CN1-21
R = 18 ±2 Ω
(25°C (77°F))
Pump proportional pressure reducing valve.
V211 Cooling Fan P/V N.A.
V212
Flow Control P/V
CN1-19 CN1-20
R = 14 ±2 Ω
(25°C (77°F))
Flow control proportional pressure reducing valve.
V213
Relief Pressure Up S/V
CN1-1 CN1-11
V = V_volt (Note 4.)
R = 26.2 ±2 Ω
(25°C (77°F))
Breaker/boost/ shear selector switch has to be selected as a boost function and the boost switch on the right-hand joystick is “ON” status.
V214
High Speed S/V
CN1-1 CN1-12
V = V_volt
R = 26.2 ±2 Ω
(25°C (77°F))
Voltage is only measured when the pressure switch (Py) is turned “ON.”
V215
Swing Priority S/V
CN1-1 CN1-13
V = V_volt
R = 26.2 ±2 Ω
(25°C (77°F))
Work mode has to be selected as a trenching mode.
V216 Reverse Fan Speed S/V N.A.
V217
Starter Relay
CN1-1 CN1-15
V = V_volt
It has to be measured in engine start up state.
V218
After Heat Relay
1-16
1-04
N.A.
Active Passive
V220
Front Pump Press. Sensor
CN3-1
CN3-2
V = IV
It has to be measured in engine stop state.
V221
Rear Pump Press. Sensor
CN3-3
CN3-4
V = IV
V222
Hyd. Oil Temperature Sensor
CN3-9 CN3-10
R = 2.45 ±0.25 k Ω (25°C (77°F))
R = 320 ±32 Ω
(80°C (176°F))
V223 Water Temperature Sensor N.A.
V224 Engine Speed Sensor N.A.
V225
Fuel Level Sensor
CN3-7 CN3-8
Empty: 5 ±0.25 k Ω
Full: 320 ±32
V226
Alternator Potential
CN2-14 CN1-8
V = 2 ±1V
V227
Dial
CN3-16 CN3-7
R = 1.0 ±0.3 k Ω
R = 4.0 ±1.5
k Ω
V228 Tps (Wheel) N.A.
V229 Parking Brake Press. Sensor N.A.
V230 E/g Control Motor Sensor N.A.
Active value: Starter switch has to be turned “ON”NOTE:
Measuring points between component and wire harness have to be connected. Passive value: Starter switch has to be turned “OFF” Measuring points between component and wire harness have to be disconnected. Measuring points are engine controller’s points and passive value is each component’s value. V_batt: Source power of equipment. FMIs (Failure Mode Identifier)
FMI 0 Above normal range (DATA VALID but ABOVE NORMAL OPERATIONAL RANGE)
FMI 1 Below normal range (DATA VALID but BELOW NORMAL OPERATIONAL RANGE)
FMI 2 Incorrect signal (DATA ERRATIC, INTERMITTENT OR INCORRECT)
FMI 3 Voltage above normal (VOLTAGE ABOVE NORMAL OR SHORTED TO HIGH SOURCE)
FMI 4 Voltage below normal (VOLTAGE BELOW NORMAL OR SHORTED TO LOW SOURCE)
FMI 5 Current below normal (CURRENT BELOW NORMAL OR OPEN CIRCUIT)
FMI 6 Current above normal (CURRENT ABOVE NORMAL OR GROUNDED CIRCUIT)
FMI 8 Abnormal signal (ABNORMAL FREQUENCY OR PULSE WIDTH OR PERIOD)
FMI 11 Failure mode not identifiable (ROOT CAUSE NOT KNOWN – Malfunction)
FMI 31 NOT AVAILABLE OR CONDITION EXISTS
Махмуд Картбаев, Нур-Султан
На кампютере написано 22 и не работают лапы упора
