![Какие функции доступны на пульте дистанционного управления? Loewe Articos 32 [Ответы 1]](/images/1019394/pimg_1022713.jpg)
Loewe Articos 32
Вопрос 683741
Какие функции доступны на пульте дистанционного управления? |
На пульте дистанционного управления доступны следующие функции: abc def RADIO -Set TV DVD STB VCR REC-MENU ghi jkl mno pqrs tuv wxyz EPG AV DISC-M CARD SV TITLE C-SET PIP P+ OK P— V— V+ -List Sound off/on (mute) Control LED for programming the remote control Switch on/off – in standby yellow key: last station ✳ Digital Recorder: bookmark forward/fast forward Digital Recorder: play/set bookmark Digital Recorder: Stop (Live picture) blue key: programme info on/off ✳ V–/V+ volume quieter/louder Call main information /in menu: Info texts on/off Status display on/off /in menu: hide menu Call AV selection PIP on/off Picture menu on/off Sound menu on/off Radio mode on/off Select programme directly in menu: enter numbers or letters Digital Recorder: freeze frame/pause (delayed viewing: start) Digital Recorder: bookmark back/rewind ✳ green key: call up personal settings ✳ red key: DR archive on/off in menu: select/set Station table list on /in menu: confirm P+/P– select program up/down Teletext mode on/off Call menu /in menu: back EPG on/off Set picture format Video operation with video operating lin on/off Timer overview Change-over switch for operation of TV, VCR, DVD recorder/player or Set Top Box ✳ You can assign other functions to the color keys for the TV mode. You can switch over the drive buttons for operating a DVD player/recorder or a video recorder. Digital Recorder: record immediately BAQ2550H_31310_021_4_GB 22.07.2004, 10:15 Uhr3 Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/20536/3 |
