Какие запчасти входят в список? Toua GSN50Е [Ответы 1]
Toua GSN50Е
Вопрос 715522
User_q715522, Редмонд
В список входят следующие запчасти: GSN50 Hex Bolt M5×10, Charger components, Nail groove fixed frame, Steel ball , Ø3, Ball spring, Top Cover, Filter, Filter Cover, Cross Recessed Bolt M4×10, Retaining Ring d0=24, Gasket, Rubber Gasket, Washer, Motor PCB Board Assembly, Mount Sleeve, Spark Plug, Hex.Socket HD M5×30, Cylinder Head Holding Screw M4× 5, Chamber clapboard, O-Retaining Ring 3.5 ×2, Washer d=5, Shaft Lock Bar, O-Ring 70× 3.53, Retaining Ring d0=62, Piston Ring 60X0.8, Adapter, Latch Spring, Straining Pin 2 ×8, Latch Spring, Cell Lever, Cell Rubber, Cell Cover, Piston Assembly, Piston Bumper, Cylinder Buffer Cover, Muffler, Lead Valve, Read Plate, Exhaust Baffle, Pushing Arm Spring, Pushing Arm Nut M5, Housing Name Plate, Specification Plate, Guide Bar, Nail Seat Protect Cover, Nailer Mouth, Locknut M5, Right Handle, Rotating shaft, Lock block, Fuel cell sponge, Trigger, Trigger spring, Mehrader Plug Assembly, Screw ST2.2×11, Screw ST2.9×8, Wiring cover, Switch spring, Hook, Controller Assembly, Countersunk Screw ST4.2×20, LED Light, Left Handle, Catch, Catch Spring, Screw ST4.2×8, Washer d=4, FixedBlock, Ribbon Spring, Nail Feeder, Nail Feeder Seat, Nail Feeder Spring, Parallel Pins 3×20, Nail Magazine, Charger Base, Adapter, Oiler, Hex.Bar Wrench M5, Safety Glasses Case Assembly, Parallel pin ,Ø4x60, Cell Cover , 0.5mm, guide sleeve, O-Ring, 59.92×d3.53, Lead frame, Chamber Head Abnormity O-Ring, Chamber positioning block, bead flange ,Ø7, Cell Cover , Ø8 , 0.3mm, motor line protecting, Motor dustproof plate, nail groove dust plate, elastic washer, M5, nail groove plate, nail groove spacer sleeve, Nail groove nut, Top Name Plate, Warning label, Battery Pack. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/632371/23
