![What is the difference between profiles? Suunto Lumi [Ответы 1]](/images/1032043/pimg_1038970.jpg)
Suunto Lumi
Вопрос 717749
What is the difference between profiles? |
An altimeter measures current altitude and is used for vertical movements. The altimeter is based on air pressure – so the lower your altitude then the more air above you. The ALTIMETER profile provides information about altitude, vertical movements, and is based on air pressure measurements. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/34453/21 |
Какие возможности предлагает Suunto Lumi помимо использования на открытом воздухе?
