![What are the specifications of the tv described in the text? Philips 47 PFL6907T/12 [Ответы 1]](/images/1073463/pimg_1099834.jpg)
Вопрос 719120
What are the specifications of the TV described in the text? |
The TV has a power supply of 220—240 V~, 50—60 Hz. The operating temperature ranges from 5 °C to 35 °C. The standby power consumption is less than 0.1 W. It complies with the 2002/96/EC and 2006/66/EC directives. The TV supports various video formats including NTSC, SECAM, PAL, MPEG2 SD/HD, MPEG4 SD/HD, and MPEG2 audio. It has Full HD resolution, 1920 x 1080p. The TV features Easy 3D, 16:9 aspect ratio, 400 Hz refresh rate, 65% color gamut, and a dynamic contrast ratio of 500,000:1. Other features include Pixel Precise HD, Perfect Motion Rate 400 Hz, Micro Dimming, and HDMI connectivity. The TV supports multiple resolutions at 60 Hz including 640 x 480, 800 x 600, 1024 x 768, 1680 x 1050, 1440 x 900, 1600 x 1200, 1400 x 1050, 1280 x 800, 1280 x 1024, 1280 x 960, and 1920 x 1080. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/78896/61 |
