![What are the noise and vibration levels measured according to en 60 745 for the... Dremel TRIO 6800 F0136800JD [Ответы 1]](/images/1008103/pimg_1282937.jpg)
Вопрос 730146
What are the noise and vibration levels measured according to EN 60 745 for the tools in the CE declaration of conformity? |
The noise level measured for the tools in the CE declaration of conformity is 71.0 dB(A) for the acoustic pressure level and 82.0 dB(A) for the acoustic power level, with a standard deviation of 3 dB. The vibration level is measured at θ m/s^2 using the hand-arm method. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/8763/6 |
