What are some important safety instructions for using the vacuum cleaner? Dyson DC29 DB Origin [Ответы 1]
Вопрос 731800
User_q731800, Редмонд
Do not pull the cord. Do not use the vacuum cleaner near heat sources or open flames. Do not run over the cord. Do not suck up water or other liquids. Do not suck up burning objects. Do not use the machine above you on stairs. Do not hold your hand near the brush head when the vacuum cleaner is on. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/14297/6
