What are some important safety precautions to consider when using the vacuum cle... Dyson DC26 ALLERGY [Ответы 1]
Dyson DC26 ALLERGY
Вопрос 731802
User_q731802, Редмонд
What are some important safety precautions to consider when using the vacuum cleaner?
Do not pull the cord. Do not use the vacuum cleaner near heat sources or open flames. Do not run over the cord. Do not suck up water or other liquids. Do not suck up burning objects. Do not use the machine above you on stairs. Do not hold your hand near the brush head when the vacuum cleaner is on. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/14305/3
