What are the recommendations for cleaning and maintenance of the refrigerator ac... Indesit B 18.025-Wt.SNG [Ответы 1]
Вопрос 733592
User_q733592, Редмонд
What are the recommendations for cleaning and maintenance of the refrigerator according to the provided text?
To clean and maintain the refrigerator, it is advised not to use abrasive detergents, bleach, or detergents containing ammonia. Instead, use a water and bicarbonate solution for cleaning the internal and exterior parts of the appliance. All removable parts can be cleaned by soaking in hot soapy water or detergent, and if you have a dishwasher, you may wash these parts in it. Remember to dry thoroughly before replacing them. Additionally, dust may deposit on the back panel, affecting the proper running of the appliance. To remove dust, vacuum carefully using the appropriate vacuum cleaner accessory. If the appliance is not in use for an extended period, clean the interior, dry thoroughly, and leave the doors open to prevent bad odors and mold formation. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/22024/4
