![What are the safety precautions for using the appliance described in the text? Zanussi ZAN1216 [Ответы 1]](/images/1028814/pimg_1294344.jpg)
Zanussi ZAN1216
Вопрос 735948
What are the safety precautions for using the appliance described in the text? |
The safety precautions for using the appliance described in the text include: Not intended for use by persons with reduced physical, sensory, or mental capabilities, unless supervised.Double insulation and no need for earthing.Children should be supervised to prevent playing with the appliance.Avoid vacuuming in wet areas, close to flammable gases, without a dustbag, with sharp objects, fluids, hot or cold cinders, or fine dust from plaster, concrete, or ash.Precautions regarding the electrical cable such as not using if damaged, not pulling or lifting the vacuum cleaner by the cable, and regular checks for damage.Keeping the vacuum cleaner in a dry place.All service and repairs must be done by an authorized Zanussi service center. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/30823/2 |
