What are the safety precautions and rules provided for the class 1 laser product... Denon D-M39 Black [Ответы 1]
Denon D-M39 Black
Вопрос 752380
User_q752380, Редмонд
What are the safety precautions and rules provided for the Class 1 laser product?
The safety precautions and rules for the Class 1 laser product include: 1. Read the instructions. 2. Keep the instructions. 3. Pay attention to all warnings. 4. Follow all instructions. 5. Do not use the device near water. 6. Clean only with a dry cloth. 7. Do not cover ventilation openings. Install according to the manufacturer's instructions. 8. Do not place near heat sources such as batteries, heaters, stoves, or other devices emitting heat. 9. Protect the cord from being stepped on or pinched, especially around the plug, sockets, and where the cables exit the device. 10. Use only accessories or parts specified by the manufacturer. 11. Use only carts, stands, tripods, brackets, or tables specified by the manufacturer or sold with the device. Be careful when using a cart to prevent tipping. 12. Disconnect the device during thunderstorms or when not in use for a long time. 13. Any technical maintenance should be carried out by specially trained personnel. Repair is necessary if the device has been damaged, such as power cable or plug failure, water entering the device, exposure to rain, malfunctioning, or falling. 14. Batteries should not be subjected to excessive heat, e.g., due to sunlight, fire, etc. CAUTION: To completely disconnect this product from the power supply, unplug the power cord from the outlet. When installing this product, make sure the used socket is within reach. These safety measures aim to reduce the risk of electric shock, exposure to radiation, and other potential hazards associated with the Class 1 laser product. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/83485/2
