How to upgrade the firmware by online Samsung UE32F5020AK [Ответы 1]
Samsung UE32F5020AK
Вопрос 764640
User_q764640, Редмонд
How to Upgrade the Firmware by Online
11 месяцев назад
To upgrade the firmware online, follow these steps: 1. Turn on the TV. 2. Confirm that your TV is connected to the Network by using the Network Status test. 3. Press the MENU button on your remote control. 4. Select 'Support' from the menu. 5. Choose 'Software Update' and then select 'Update now'. 6. The TV will start downloading the firmware update. 7. Once the firmware upgrade is completed, the TV will turn off and then back on by itself. 8. The message 'Connecting to the network server.' will be displayed. 9. If the TV finds a higher firmware version from the server, it will ask you to update to the new version. Press 'Yes' to proceed. 10. The TV will then update the software automatically. Your TV will turn itself off and on again after completing the update. 11. Finally, you will see a message confirming the update. Your TV is now successfully updated to the latest firmware version. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/125625/5
