What are the technical specifications of the speaker unit described in the text? Panasonic TY-SP65PV600 [Ответы 1]
Вопрос 771877
User_q771877, Редмонд
The speaker unit has a rated impedance of 8 Ω, a rated input of 15 W. The midrange consists of two oval-shaped speakers measuring 5.7 cm x 12.6 cm each, while the tweeter is a 5.2 cm diameter speaker. The dimensions of the speaker unit are 100 mm x 985 mm x 90 mm, with a weight of 2.3 kg per speaker. The cabinet material is made of Styrene plastic. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/149918/5
