What are the main components and functions of the sc-091 2 gb according to the p... Scarlett SC-091 [Ответы 1]
Scarlett SC-091
Вопрос 773766
User_q773766, Редмонд
What are the main components and functions of the SC-091 2 GB according to the provided description in Russian?
The main components and functions of the SC-091 2 GB according to the provided description in Russian are as follows: 1. Housing, 2. Timer switch, 3. Indicator light, 4. Selector dial. The heating elements can be controlled in different configurations: Both heating elements switched off (1), Only upper heating element switched on (2), Both upper and lower heating elements switched on (3), Only lower heating element switched on (4). Additionally, the specifications include power supply of ~230V / 50 Hz, power consumption of 650 W, weight ranging from 2.85 to 3.62 kg, and dimensions of 410 mm x 255 mm x 250 mm. Подробнее смотрите по следующей ссылке https://mcgrp.ru/files/viewer/156166/2
